* | Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-04-26 | 16 | -233/+314 | |
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball. | |||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 12 | -12/+12 | |
* | Added support for @appendix and @preface. | Joel Sherrill | 1999-10-11 | 1 | -0/+12 | |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 2 | -5/+7 | |
* | Enhanced to support @email{} as supported in texi2html in texinfo 4.0. | Joel Sherrill | 1999-10-07 | 1 | -0/+5 | |
| | | | | | This way we maintain compatibility but continue to use the better, more flexible tool. | |||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 2 | -2/+2 | |
| | | | | pdf version of figures. | |||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 6 | -13/+27 | |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 | |
* | Sanitized. | Joel Sherrill | 1999-04-06 | 1 | -3/+0 | |
* | Removed. | Joel Sherrill | 1999-04-06 | 6 | -2860/+0 | |
* | Minor change to ease debugging. | Joel Sherrill | 1998-10-27 | 1 | -1/+3 | |
* | New picture. | Joel Sherrill | 1998-10-20 | 1 | -0/+0 | |
* | Added test case for table -- barfs when optimization is enabled | Joel Sherrill | 1998-05-12 | 1 | -0/+27 | |
* | RTEMS stuff now browseable for 1st time. Not completed. | Joel Sherrill | 1998-04-14 | 2 | -3/+8 | |
* | Added emacs Ada tags stuff | Joel Sherrill | 1998-04-14 | 3 | -0/+444 | |
* | building up src2html | Joel Sherrill | 1998-04-14 | 1 | -0/+37 | |
* | base changes for moving and better error checking | Joel Sherrill | 1998-04-14 | 1 | -2/+21 | |
* | New file. Copied from Avenger. | Joel Sherrill | 1998-04-14 | 1 | -0/+18 | |
* | Added Ada support by copying the script from Avenger. | Joel Sherrill | 1998-04-14 | 1 | -40/+155 | |
* | switched to gcc | Joel Sherrill | 1998-04-14 | 1 | -2/+5 | |
* | New files | Joel Sherrill | 1998-04-14 | 32 | -0/+2942 | |
* | Changed from Top to index as top node | Joel Sherrill | 1998-04-13 | 1 | -1/+1 | |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 | |
* | Moved from common directory since they belong to the texi2www distribution. | Joel Sherrill | 1998-04-03 | 5 | -0/+0 | |
* | Removed incorrect comment. | Joel Sherrill | 1998-04-03 | 1 | -1/+0 | |
* | Renamed. | Joel Sherrill | 1998-04-03 | 1 | -1/+1 | |
* | Nowbiulds html and ps. Info not supported. | Joel Sherrill | 1998-04-03 | 1 | -3/+4 | |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 | |
| | | | | to specify the base of the name. BASEnnnn.html | |||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 | |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 | |
* | Base file | Joel Sherrill | 1998-04-03 | 4 | -1/+53 | |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 2 | -2/+2 | |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 4 | -0/+2122 | |
* | Localized for use in doc tree. | Joel Sherrill | 1998-03-27 | 1 | -2/+7 | |
* | removed @ifinfo around something needed for html structure | Joel Sherrill | 1998-03-26 | 1 | -2/+2 | |
* | new test cases | Joel Sherrill | 1998-02-11 | 2 | -0/+92 | |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 10 | -10/+10 | |
* | Added @table/@end table capability along with the avdas.d test case where | Joel Sherrill | 1998-02-06 | 3 | -3/+363 | |
| | | | | this capability was first used. | |||||
* | Added code to more correctly process abstract types (handle, range, etc). | Joel Sherrill | 1998-02-05 | 2 | -22/+76 | |
* | Modified output of @Example style in MsWord output routine so it would | Joel Sherrill | 1998-01-30 | 2 | -4/+36 | |
| | | | | be one paragraph with manual line breaks rather than multiple paragraphs.. | |||||
* | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1998-01-23 | 1 | -11/+29 | |
| | | | | doing the HWAPI manual. | |||||
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 3 | -10/+203 | |
| | | | | Application Cindy has written can transform into a nice Word document. | |||||
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 | |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 | |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 | |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | |||||
* | Added command line options for next, previous, and up node. | Joel Sherrill | 1997-08-15 | 1 | -7/+28 | |
| | | | | | Added error check to insure we don't write over a .texi file given to us as input. | |||||
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 | |
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | |||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
* | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 | |
