* | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1998-01-23 | 1 | -11/+29 | |
| | | | | doing the HWAPI manual. | |||||
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 3 | -10/+203 | |
| | | | | Application Cindy has written can transform into a nice Word document. | |||||
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 | |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 | |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 | |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | |||||
* | Added command line options for next, previous, and up node. | Joel Sherrill | 1997-08-15 | 1 | -7/+28 | |
| | | | | | Added error check to insure we don't write over a .texi file given to us as input. | |||||
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 | |
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | |||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 | |
* | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 | |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 12 | -28/+51 | |
* | Initial revision | Joel Sherrill | 1997-05-27 | 15 | -0/+2547 | |
