* archive/texi2www-960103.tgz (rtems-4-6-branch only): Remove.
* archive/ (rtems-4-6-branch only): Remove.
* Makefile.am (rtems-4-6-branch only): Reflect change above.
* texi2www: Add support for @ifnottex.
* configure.ac: Remove AC_CONFIG_AUX_DIR.
* src2html: Remove.
* src2html1.4a: Remove.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* Ctags/Makefile.am: Remove AUTOMAKE_OPTIONS.
* FreeBSD/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ctags-emacs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Autoupdate to 2.52.
Remove pdl2texi.
* Makefile.am: Remove pdl2texi.
* ctags-emacs/Makefile.am: Ditto.
* FreeBSD/Makefile.am: Ditto.
* Ctags/Makefile.am: Ditto.
* Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Adds a -I <path> option to texi2www. This option is supposed to
compatible to the option of the same name in makeinfo, texi2dvi etc.
[This patch actually is kind of a hack, but it works :]
fixes handling of word-replace and removes tool/update.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
that addresses the following:
The patch below should
* fix the *pdf cleanup handling
* fix dependencies between pdf-documents and texi-files
It also contains an attempt to let networking/schedule.t use states.pdf
instead of ascii graphics, but though each pdf image looks nice, it
comes out weirdly distorted in the main pdf document.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
This way we maintain compatibility but continue to use the better,
more flexible tool.
pdf version of figures.
figures included.
