* texi2www/texi2www: Add some new texinfo commands.
* base.h: Remove Lines, Verbose, EXTERN.
* menu2.c: Add Lines, Verbose. Remove EXTERN.
* base.h: Remove BlankAsWarnings.
* base.h: Remove NumberOf*.
* address.h, address.inl, chain.c, chain.h, system.h:
Eliminate unsigned8, unsigned16, unsigned32.
Use size_t, ptrdiff_t, intptr_t for 64bit compliance.
* chain.c: Reflect removal of isr.h.
* isr.h: Remove.
* Makefile.am: Remove isr.h.
* texi2www: Add provisory support for @image.
* Makefile.am: Cosmetics.
* system.h: Remove USE_INLINES.
* chain.c: Remove USE_INLINES.
* configure.ac: Merger from rtems-4-6-branch.
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in,
rtems_support.html.in, ada_user/ada_user.texi: Merge from branch.
* acinclude.m4, images/rtems_logo.jpg: New files.
* SUPPORT, tools/texi2www/archive/texi2www-960103.tgz: Removed.
* texi2www: Add support for @ifnottex.
PR 347/rtems
* rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline
assembly so it correctly generates on newer gcc's.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* .cvsignore: Add autom4te.cache.
* Ctags/Makefile.am: Remove AUTOMAKE_OPTIONS.
* FreeBSD/Makefile.am: Remove AUTOMAKE_OPTIONS.
* ctags-emacs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* configure.ac: Autoupdate to 2.52.
Remove pdl2texi.
* Makefile.am: Remove pdl2texi.
* ctags-emacs/Makefile.am: Ditto.
* FreeBSD/Makefile.am: Ditto.
* Ctags/Makefile.am: Ditto.
* Makefile.am: Removed definition of ACLOCAL_AMFLAGS.
* Makefile.am: Removed GENERATED_FILES from list of TEXINFOS.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Adds a -I <path> option to texi2www. This option is supposed to
compatible to the option of the same name in makeinfo, texi2dvi etc.
[This patch actually is kind of a hack, but it works :]
fixes handling of word-replace and removes tool/update.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
