* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -3/+4 |
* | Enhanced to support @email{} as supported in texi2html in texinfo 4.0. | Joel Sherrill | 1999-10-07 | 1 | -0/+5 |
| | | | | | This way we maintain compatibility but continue to use the better, more flexible tool. | ||||
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 3 | -10/+18 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Minor change to ease debugging. | Joel Sherrill | 1998-10-27 | 1 | -1/+3 |
* | New picture. | Joel Sherrill | 1998-10-20 | 1 | -0/+0 |
* | Changed from Top to index as top node | Joel Sherrill | 1998-04-13 | 1 | -1/+1 |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 |
* | Moved from common directory since they belong to the texi2www distribution. | Joel Sherrill | 1998-04-03 | 5 | -0/+0 |
* | Removed incorrect comment. | Joel Sherrill | 1998-04-03 | 1 | -1/+0 |
* | Renamed. | Joel Sherrill | 1998-04-03 | 1 | -1/+1 |
* | Nowbiulds html and ps. Info not supported. | Joel Sherrill | 1998-04-03 | 1 | -3/+4 |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 |
| | | | | to specify the base of the name. BASEnnnn.html | ||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 |
* | Base file | Joel Sherrill | 1998-04-03 | 4 | -1/+53 |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 2 | -2/+2 |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 4 | -0/+2122 |
