* | Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>: | Joel Sherrill | 2000-05-31 | 1 | -3/+17 |
| | | | | | | Adds a -I <path> option to texi2www. This option is supposed to compatible to the option of the same name in makeinfo, texi2dvi etc. [This patch actually is kind of a hack, but it works :] | ||||
* | Enhanced to support @email{} as supported in texi2html in texinfo 4.0. | Joel Sherrill | 1999-10-07 | 1 | -0/+5 |
| | | | | | This way we maintain compatibility but continue to use the better, more flexible tool. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -0/+3 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Changed from Top to index as top node | Joel Sherrill | 1998-04-13 | 1 | -1/+1 |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 |
| | | | | to specify the base of the name. BASEnnnn.html | ||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 |
* | Base file | Joel Sherrill | 1998-04-03 | 1 | -0/+4 |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 1 | -1/+1 |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 1 | -0/+1202 |
