* | Changed from Top to index as top node | Joel Sherrill | 1998-04-13 | 1 | -1/+1 |
* | Moved the terminate node since the "cprev" was being overwritten. | Joel Sherrill | 1998-04-03 | 1 | -2/+2 |
* | Added shortname generation support with the capability for the user | Joel Sherrill | 1998-04-03 | 1 | -5/+37 |
| | | | | to specify the base of the name. BASEnnnn.html | ||||
* | Added fourth icon which takes user back to the index | Joel Sherrill | 1998-04-03 | 1 | -26/+43 |
* | Added -header and -dirfile options. | Joel Sherrill | 1998-04-03 | 1 | -2/+23 |
* | Base file | Joel Sherrill | 1998-04-03 | 1 | -0/+4 |
* | Changed Perl executable location | Joel Sherrill | 1998-04-03 | 1 | -1/+1 |
* | Base files from texi2www-960103 | Joel Sherrill | 1998-04-03 | 1 | -0/+1202 |
