PR 1793/doc
* Makefile.am, configure.ac, bmenu/bmenu2.c: Convert from texi2www to
texi2html.
* texi2www/ChangeLog, texi2www/Makefile.am, texi2www/dir-arrow.gif,
texi2www/missing-arrow.gif, texi2www/next-arrow.gif,
texi2www/prev-arrow.gif, texi2www/texi2dvi, texi2www/texi2www,
texi2www/texi2www.texi, texi2www/up-arrow.gif: Removed.
* Makefile.am: Cosmetics.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
