path: root/doc/tools/pdl2texi (follow)
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-111-2/+3
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-1/+1
| | | | pdf version of figures.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-012-2/+7
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Sanitized.Joel Sherrill1999-04-061-3/+0
* Removed.Joel Sherrill1999-04-065-2170/+0
* Added test case for table -- barfs when optimization is enabledJoel Sherrill1998-05-121-0/+27
* new test casesJoel Sherrill1998-02-112-0/+92
* Added @table/@end table capability along with the avdas.d test case whereJoel Sherrill1998-02-063-3/+363
| | | | this capability was first used.
* Added code to more correctly process abstract types (handle, range, etc).Joel Sherrill1998-02-052-22/+76
* Modified output of @Example style in MsWord output routine so it wouldJoel Sherrill1998-01-302-4/+36
| | | | be one paragraph with manual line breaks rather than multiple paragraphs..
* Added Code to dop the output in a format which a custom Visual BasicJoel Sherrill1998-01-213-10/+203
| | | | Application Cindy has written can transform into a nice Word document.
* This commit was generated by cvs2svn to compensate for changes in r930,Joel Sherrill1997-06-169-0/+1379
|\ | | | | which included commits to RCS files with non-trunk default branches.
| * base PDL 2 TEXIJoel Sherrill1997-06-169-0/+1379
* Initial revisionJoel Sherrill1997-06-167-0/+5348
