* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -2/+3 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -2/+7 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Sanitized. | Joel Sherrill | 1999-04-06 | 1 | -3/+0 |
* | Removed. | Joel Sherrill | 1999-04-06 | 5 | -2170/+0 |
* | Added test case for table -- barfs when optimization is enabled | Joel Sherrill | 1998-05-12 | 1 | -0/+27 |
* | new test cases | Joel Sherrill | 1998-02-11 | 2 | -0/+92 |
* | Added @table/@end table capability along with the avdas.d test case where | Joel Sherrill | 1998-02-06 | 3 | -3/+363 |
| | | | | this capability was first used. | ||||
* | Added code to more correctly process abstract types (handle, range, etc). | Joel Sherrill | 1998-02-05 | 2 | -22/+76 |
* | Modified output of @Example style in MsWord output routine so it would | Joel Sherrill | 1998-01-30 | 2 | -4/+36 |
| | | | | be one paragraph with manual line breaks rather than multiple paragraphs.. | ||||
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 3 | -10/+203 |
| | | | | Application Cindy has written can transform into a nice Word document. | ||||
* | This commit was generated by cvs2svn to compensate for changes in r930, | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
|\ | | | | | which included commits to RCS files with non-trunk default branches. | ||||
| * | base PDL 2 TEXI | Joel Sherrill | 1997-06-16 | 9 | -0/+1379 |
* | Initial revision | Joel Sherrill | 1997-06-16 | 7 | -0/+5348 |
