* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -1/+2 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Added @table/@end table capability along with the avdas.d test case where | Joel Sherrill | 1998-02-06 | 1 | -3/+101 |
| | | | | this capability was first used. | ||||
* | Added code to more correctly process abstract types (handle, range, etc). | Joel Sherrill | 1998-02-05 | 1 | -22/+65 |
* | Modified output of @Example style in MsWord output routine so it would | Joel Sherrill | 1998-01-30 | 1 | -2/+34 |
| | | | | be one paragraph with manual line breaks rather than multiple paragraphs.. | ||||
* | Added Code to dop the output in a format which a custom Visual Basic | Joel Sherrill | 1998-01-21 | 1 | -10/+196 |
| | | | | Application Cindy has written can transform into a nice Word document. | ||||
* | Initial revision | Joel Sherrill | 1997-06-16 | 1 | -0/+3256 |
