* | Added support for @appendix and @preface. | Joel Sherrill | 1999-10-11 | 1 | -0/+12 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -1/+2 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed. | Joel Sherrill | 1999-04-06 | 1 | -690/+0 |
* | removed @ifinfo around something needed for html structure | Joel Sherrill | 1998-03-26 | 1 | -2/+2 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 10 | -10/+10 |
* | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1998-01-23 | 1 | -11/+29 |
| | | | | doing the HWAPI manual. | ||||
* | Test document. | Joel Sherrill | 1997-10-31 | 1 | -0/+690 |
* | New test file. | Joel Sherrill | 1997-10-31 | 1 | -4/+4 |
* | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1997-10-31 | 1 | -218/+236 |
| | | | | | | | | | was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | ||||
* | Added command line options for next, previous, and up node. | Joel Sherrill | 1997-08-15 | 1 | -7/+28 |
| | | | | | Added error check to insure we don't write over a .texi file given to us as input. | ||||
* | removed binary files | Joel Sherrill | 1997-08-04 | 3 | -0/+0 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 10 | -26/+44 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 13 | -0/+2247 |
