for details.
PR 1793/doc
* Makefile.am, configure.ac, bmenu/bmenu2.c: Convert from texi2www to
texi2html.
* texi2www/ChangeLog, texi2www/Makefile.am, texi2www/dir-arrow.gif,
texi2www/missing-arrow.gif, texi2www/next-arrow.gif,
texi2www/prev-arrow.gif, texi2www/texi2dvi, texi2www/texi2www,
texi2www/texi2www.texi, texi2www/up-arrow.gif: Removed.
* base.h: Remove Lines, Verbose, EXTERN.
* menu2.c: Add Lines, Verbose. Remove EXTERN.
* base.h: Remove BlankAsWarnings.
* base.h: Remove NumberOf*.
* address.h, address.inl, chain.c, chain.h, system.h:
Eliminate unsigned8, unsigned16, unsigned32.
Use size_t, ptrdiff_t, intptr_t for 64bit compliance.
* chain.c: Reflect removal of isr.h.
* isr.h: Remove.
* Makefile.am: Remove isr.h.
* Makefile.am: Cosmetics.
* system.h: Remove USE_INLINES.
* chain.c: Remove USE_INLINES.
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
figures included.
doing the HWAPI manual.
was necessary to fix some bugs and to support the "@subsubsection",
"@raise", and "@lower" commands. The major known bug was that
single section chapters were not being processed correctly.
Added the -c option so chapter names do not always have to included
in the node names.
Added error check to insure we don't write over a .texi file given
to us as input.
