2000-06-01 | Removed old bmenu version. | Joel Sherrill | 1 | -1061/+0 | |
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Added support for @appendix and @preface. | Joel Sherrill | 1 | -0/+12 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -1/+2 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1998-03-26 | removed @ifinfo around something needed for html structure | Joel Sherrill | 1 | -2/+2 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1998-01-23 | Fixed some "NodeNameIncludesChapterName" problems which were uncovered | Joel Sherrill | 1 | -11/+29 | |
doing the HWAPI manual. | |||||
1997-10-31 | Replaced the algorithm used to build the texinfo nodes and menus. This | Joel Sherrill | 1 | -218/+236 | |
was necessary to fix some bugs and to support the "@subsubsection", "@raise", and "@lower" commands. The major known bug was that single section chapters were not being processed correctly. Added the -c option so chapter names do not always have to included in the node names. | |||||
1997-08-15 | Added command line options for next, previous, and up node. | Joel Sherrill | 1 | -7/+28 | |
Added error check to insure we don't write over a .texi file given to us as input. | |||||
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+6 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+985 | |
