2017-01-11 | Remove texinfo format documentation. Replaced by Sphinx formatted documentation. | Joel Sherrill | 1 | -96/+0 | |
closes #2812. | |||||
2012-05-11 | Remove All CVS Id Strings Possible Using a Script | Joel Sherrill | 1 | -2/+0 | |
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed. | |||||
2009-12-10 | Whitespace removal. | Ralf Corsepius | 1 | -4/+4 | |
2007-12-11 | 2007-12-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -7/+0 | |
* base.h: Remove Lines, Verbose, EXTERN. * menu2.c: Add Lines, Verbose. Remove EXTERN. | |||||
2007-12-11 | 2007-12-11 Ralf Corsepius <ralf.corsepius@rtems.org> | Ralf Corsepius | 1 | -1/+0 | |
* base.h: Remove BlankAsWarnings. | |||||
* base.h: Remove NumberOf*. | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1998-02-06 | Updated copyrights | Joel Sherrill | 1 | -1/+1 | |
1997-06-04 | added CVS Id string | Joel Sherrill | 1 | -0/+7 | |
1997-05-27 | Initial revision | Joel Sherrill | 1 | -0/+106 | |
