* | 2011-12-06 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2011-12-06 | 1 | -0/+10 |
| | | | | | | | | | | PR 1793/doc * Makefile.am, configure.ac, bmenu/bmenu2.c: Convert from texi2www to texi2html. * texi2www/ChangeLog, texi2www/Makefile.am, texi2www/dir-arrow.gif, texi2www/missing-arrow.gif, texi2www/next-arrow.gif, texi2www/prev-arrow.gif, texi2www/texi2dvi, texi2www/texi2www, texi2www/texi2www.texi, texi2www/up-arrow.gif: Removed. | ||||
* | 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2011-02-02 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.68, automake-1.11.1. | ||||
* | 2010-04-23 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-04-23 | 1 | -0/+4 |
| | | | | * texi2www/texi2www: Add some new texinfo commands. | ||||
* | 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-12-02 | 1 | -0/+4 |
| | | | | * configure.ac: New BUG-REPORT address. | ||||
* | 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org> | Ralf Corsepius | 2006-10-17 | 1 | -0/+4 |
| | | | | * configure.ac: Require autoconf-2.60. Require automake-1.10. | ||||
* | 2004-09-24 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-09-24 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake > 1.9. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 1 | -0/+4 |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 1 | -0/+4 |
| | | | | * configure.ac: Merger from rtems-4-6-branch. | ||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 1 | -0/+4 |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | ||||
* | 2003-02-14 Till Straumann <strauman@slac.stanford.edu> | Joel Sherrill | 2003-02-14 | 1 | -0/+29 |
| | | | | | | PR 347/rtems * rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline assembly so it correctly generates on newer gcc's. | ||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-02-14 | 1 | -0/+7 |
* | 2003-02-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-02-11 | 1 | -0/+4 |
| | | | | * configure.ac: AM_INIT_AUTOMAKE([1.7.2]). | ||||
| | | | | * configure.ac: AC_PREREQ(2.57). | ||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 1 | -0/+6 |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | ||||
* | 2002-10-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-09 | 1 | -0/+4 |
| | | | | * .cvsignore: Add autom4te.cache. | ||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 1 | -0/+7 |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | ||||
* | 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-22 | 1 | -0/+6 |
| | | | | | | * configure.ac: Autoupdate to 2.52. Remove pdl2texi. * Makefile.am: Remove pdl2texi. | ||||
* | 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-01-18 | 1 | -0/+4 |
| | | | | * Makefile.am: Require automake-1.5. | ||||
* | 2000-09-22 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-09-22 | 1 | -0/+4 |
| | | | | * Makefile.am: Removed definition of ACLOCAL_AMFLAGS. | ||||
* | Adding ChangeLogs. | Joel Sherrill | 2000-08-25 | 1 | -0/+3 |
