* | doc/texi2any_init.in: Correct link to Library index.html | Joel Sherrill | 2013-03-11 | 1 | -1/+1 |
* | doc: Support texi2any and texi2html | Joel Sherrill | 2013-02-26 | 1 | -0/+20 |
This was tested with texi2html-1.82-5.1.el6.noarch and a locally built texinfo 5.0. These are completely different implementations and require different invocations. The Makefile dependencies appear to work but are likely not perfect at this point. The key point is that the autoconf probe detects which to use and responds accordingly with preference given to texi2any. |
