* | Added text from Erik Ivanenko <erik.ivanenko@utoronto.ca> describing | Joel Sherrill | 1998-06-01 | 2 | -144/+172 |
| | | | | transition from real to protected mode and modified the spacing. | ||||
* | Corrected paths after moving all supplements into a subdirectory. | Joel Sherrill | 1998-04-11 | 22 | -82/+82 |
* | Taking care of minor build problems | Joel Sherrill | 1998-03-30 | 2 | -5/+3 |
* | Making the stanza right and improving the way the isntall directories are built | Joel Sherrill | 1998-03-30 | 6 | -91/+45 |
* | Corrected distribution levels for html | Joel Sherrill | 1998-03-30 | 6 | -6/+6 |
* | Added distribution level to each manual | Joel Sherrill | 1998-03-30 | 6 | -6/+18 |
* | New file. Basically m68k version with Hitachi SH comments thrown in. | Joel Sherrill | 1998-03-26 | 1 | -0/+102 |
* | Added variables for dates and revision info | Joel Sherrill | 1998-03-26 | 6 | -24/+24 |
* | updates | Joel Sherrill | 1998-02-11 | 17 | -655/+540 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 106 | -106/+106 |
* | minor updates .. mostly version | Joel Sherrill | 1998-01-23 | 10 | -76/+76 |
* | Modified SPARC to PowerPC. Modified specific requirements to be | Jennifer Averett | 1997-12-02 | 2 | -14/+14 |
| | | | | for the PowerPC instead of the SPARC. | ||||
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Fixed wildcard in copy command. | Joel Sherrill | 1997-08-04 | 1 | -1/+1 |
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 |
* | Corrected bug in Makefile | Joel Sherrill | 1997-07-31 | 1 | -1/+1 |
* | corrected typos and changes LANGUAGE to RTEMS-LANGUAGE. | Joel Sherrill | 1997-07-31 | 11 | -18/+30 |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 |
| | | | | | This version has had some initial work done to convert it to be PowerPC specific. | ||||
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 94 | -1/+292 |
* | added CVS Id string | Joel Sherrill | 1997-06-04 | 1 | -0/+2 |
* | changed edition and version information | Joel Sherrill | 1997-06-04 | 7 | -12/+12 |
* | Changed bitwise OR's used to build up option and attribute sets | Joel Sherrill | 1997-05-31 | 5 | -10/+10 |
| | | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997" | ||||
* | fixed typos | Joel Sherrill | 1997-05-30 | 14 | -51/+52 |
* | updated version number | Joel Sherrill | 1997-05-29 | 2 | -2/+2 |
* | version changed | Joel Sherrill | 1997-05-28 | 5 | -10/+10 |
* | 4.0.0 release docs | Joel Sherrill | 1997-05-28 | 9 | -14/+14 |
* | Initial revision | Joel Sherrill | 1997-05-27 | 94 | -0/+11962 |
