* | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-01-07 | 15 | -1383/+9 |
| | | | | | | | | | * mips64orion/.cvsignore, mips64orion/BSP_TIMES, mips64orion/ChangeLog, mips64orion/Makefile.am, mips64orion/bsp.t, mips64orion/callconv.t, mips64orion/cpumodel.t, mips64orion/cputable.t, mips64orion/fatalerr.t, mips64orion/intr_NOTIMES.t, mips64orion/memmodel.t, mips64orion/mips64orion.texi, mips64orion/preface.texi, mips64orion/timeBSP.t: Removed. | ||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 24 | -12/+48 |
| | | | | * Makefile.am: Cosmetics. | ||||
* | 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-11 | 24 | -22/+79 |
* | 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-26 | 22 | -0/+77 |
| | | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 22 | -11/+55 |
| | | | | * cpumodel.t: Obsoleting HP PA-RISC port and removing all references. | ||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 15 | -1336/+8 |
| | | | | | | | | * hppa1_1/.cvsignore, hppa1_1/ChangeLog, hppa1_1/Makefile.am, hppa1_1/SIMHPPA_TIMES, hppa1_1/bsp.t, hppa1_1/callconv.t, hppa1_1/cpumodel.t, hppa1_1/cputable.t, hppa1_1/fatalerr.t, hppa1_1/hppa1_1.texi, hppa1_1/intr_NOTIMES.t, hppa1_1/memmodel.t, hppa1_1/preface.texi, hppa1_1/timeSIMHPPA.t: Removed. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 6 | -6/+15 |
| | | | | * Makefile.am: Merger from rtems-4-6-branch. | ||||
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 10 | -10/+25 |
* | 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-22 | 8 | -8/+20 |
* | 2003-09-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-09-20 | 3 | -2/+6 |
| | | | | | * supplement.am: Add -I $(top_builddir) TEXI2WWW_ARGS. * Makefile.am: Purge hppa1.1. | ||||
* | 2003-09-19 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-19 | 2 | -0/+5 |
| | | | | * arm.texi: Merge from branch. | ||||
| | | | | * c4x.texi: Merge from branch. | ||||
| | | | | * hppa1_1.texi: Merge from branch. | ||||
| | | | | * i386.texi: Merge from branch. | ||||
| | | | | * i960.texi: Merge from branch. | ||||
| | | | | * m68k.texi: Merge from branch. | ||||
| | | | | * mips.texi: Merge from branch. | ||||
| | | | | * mips64orion.texi: Merge from branch. | ||||
| | | | | * powerpc.texi: Merge from branch. | ||||
| | | | | * sh.texi: Merge from branch. | ||||
| | | | | * sparc.texi: Merge from branch. | ||||
| | | | | * template.texi: Merge from branch. | ||||
* | Merger from rtems-4-6-branch | Ralf Corsepius | 2003-05-22 | 22 | -12/+56 |
* | 2003-01-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-28 | 2 | -0/+42 |
| | | | | * .cvsignore: New file. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+5 |
| | | | | * template.texi: Set @setfilename template.info. | ||||
| | | | | * sparc.texi: Set @setfilename sparc.info. | ||||
| | | | | * sh.texi: Set @setfilename sh.info. | ||||
| | | | | * powerpc.texi: Set @setfilename powerpc.info. | ||||
| | | | | * mips64orion.texi: Set @setfilename mips64orion.info. | ||||
| | | | | * mips.texi: Set @setfilename mips.info. | ||||
| | | | | * m68k.texi: Set @setfilename m68k.info. | ||||
| | | | | * i960.texi: Set @setfilename i960.info. | ||||
| | | | | * i386.texi: Set @setfilename i386.info. | ||||
| | | | | * hppa1_1.texi: Set @setfilename hppa1_1.info. | ||||
| | | | | * c4x.texi: Set @setfilename c4x.info. | ||||
| | | | | * arm.texi: Set @setfilename arm.info. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 2 | -1/+16 |
| | | | | * Makefile.am: Add c4x, cosmetical changes. | ||||
* | 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-25 | 5 | -23/+131 |
| | | | | | | * Makefile.am: New. * c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them building. | ||||
* | 2003-01-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-24 | 12 | -0/+1378 |
| | | | | | | * BSP_TIMES, bsp.t, c4x.texi, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, timeBSP.t: New files. These should have been added long ago. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 2 | -4/+4 |
| | | | | * supplements.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF. | ||||
* | 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-24 | 22 | -111/+155 |
| | | | | * Makefile.am: Put GENERATED_FILES into $builddir. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-23 | 2 | -3/+8 |
| | | | | | * supplements.am: Use automake rules to build ps, pdf, info. Various minor changes. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 44 | -162/+184 |
| | | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort. | ||||
* | 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-01-22 | 3 | -897/+5 |
| | | | | | * wksheets.texi: Remove from CVS. * timing.texi: Remove from CVS. | ||||
* | 2003-01-21 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-21 | 33 | -44/+88 |
| | | | | * stamp-vti, version.texi: Regenerated. | ||||
* | 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-08 | 2 | -1/+5 |
| | | | | * supplement.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS. | ||||
* | 2002-11-13 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-11-13 | 33 | -44/+88 |
* | 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com> | Joel Sherrill | 2002-11-13 | 2 | -123/+53 |
| | | | | * intr_NOTIMES.t: Real version submitted. | ||||
* | 2002-10-24 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-10-24 | 33 | -44/+88 |
* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 3 | -278/+284 |
| | | | | | | * BSP_TIMES, wksheets.texi: Updated to reflect ARM times reported by Jay Monkman <jmonkman@adventnetworks.com>. These times are subject to change as he tunes the ARM port and their BSP. |
