path: root/doc/supplements (follow)
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-2433-44/+88
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-023-278/+284
| | | | | | * BSP_TIMES, wksheets.texi: Updated to reflect ARM times reported by Jay Monkman <jmonkman@adventnetworks.com>. These times are subject to change as he tunes the ARM port and their BSP.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-312-1/+5
| | | | * Makefile.am: Added arm subdirectory.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-319-27/+51
| | | | * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-314-28/+37
| | | | | * .cvsignore: Corrected some errors. * intr_NOTIMES.t, timeBSP.t: Replaced XXX's with real info.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-313-8/+20
| | | | * timeMVME136.t, timedata.t: Replaced XXX's with real info.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-312-13/+17
| | | | | * callconf.t: Added some markups for fonts and clarified some places.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-3020-44/+44
| | | | | * stamp-vti, verstion.texi: Regenerated.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-17/+22
| | | | * .cvsignore: Corrected by tailoring for the ARM.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-0/+39
| | | | * .cvsignore: New file.
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-3017-0/+2175
| | | | | | | * BSP_TIMES, ChangeLog, Makefile.am, arm.texi, bsp.t, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, stamp-vti, timeBSP.t, timing.texi, version.texi, wksheets.texi: New files as ARM supplement initial version added.
* BSPDIR=/opt/rtems/powerpc-rtems/mcp750/lib/includeJoel Sherrill2002-07-262-1/+6
| | | | | | | | | | | | | | CPUDIR=/opt/rtems/powerpc-rtems/include cd $BSPDIR find . -name "*.h" | while read f do if [ -r ${CPUDIR}/${f} ] ; then echo Conflict on ${f} fi done
* 2002-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-282-0/+75
| | | | | * intr_NOTIMES.t: Per PR70 incorporate the posting by Zoltan Kocsi <zoltan@bendor.com.au> explaining a m68k vectoring trick.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-2822-11/+44
| | | | * Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-03-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-03-012-0/+40
* 2001-02-14 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-142-1/+5
| | | | * mips: New supplement.
* 2002-02-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-02-1415-0/+1278
| | | | | | * bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi, preface.texi, stamp-vti, timeBSP.t, version.texi: New files.
* regeneratedJoel Sherrill2002-01-2018-36/+54
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-2020-37/+41
| | | | * supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-1820-10/+50
| | | | * Makefile.am: Require automake-1.5.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-1718-0/+54
| | | | * .cvsignore: Added rtems_header.html and rtems_footer.html.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-17119-137/+146
* Adding ChangeLogs.Joel Sherrill2000-08-2510-0/+30
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-1410-9/+3
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-1030-73/+87
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
* Patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de> to:Joel Sherrill2000-06-011-2/+10
| | | | | | | | | | This patch changes the installation directory of the supplements to supplements/<cpu>. This allows browsing the html files inside of the source tree, because after having applied this patch, the structure of the html installation directory hierarchy is the same as the directory structure of the source tree.
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-0145-539/+512
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-0120-289/+257
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* New files. First attempt.Joel Sherrill2000-04-2710-0/+297
* Removed -- temporary files.Joel Sherrill2000-04-278-11515/+0
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-2639-1507/+12606
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Changed copyright date to 1999.Joel Sherrill1999-11-16101-101/+101
* Fixing many lines that are too long to format cleanly.Joel Sherrill1999-10-252-3/+5
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-119-45/+54
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-079-9/+9
| | | | pdf version of figures.
* Enabled table of contents generation so the left hand side of the PDFJoel Sherrill1999-10-079-9/+9
| | | | viewer can have section headings.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-0118-27/+72
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-039-9/+0
* Changed date.Joel Sherrill1999-04-231-0/+2
* Added info based on i960HA support.Joel Sherrill1999-04-191-10/+8
* First Cut at Hitachi SH.Joel Sherrill1998-11-2512-0/+1222
* New files copied from template and personalized.Joel Sherrill1998-11-2312-0/+1314
* Applied updates from remote work while doing class.Joel Sherrill1998-11-197-98/+84
* Moved things around so html and clean were above stanzas which generateJoel Sherrill1998-10-197-113/+107
| | | | chapters.
* All of the Supplemental manuals are now generated as automaticallyJoel Sherrill1998-10-1922-511/+159
| | | | as possible.
* No node infoJoel Sherrill1998-10-191-45/+1
* Renamed.Joel Sherrill1998-10-193-645/+0
* Renamed memmodel.texi to memmodel.t.Joel Sherrill1998-10-191-119/+0
* Renamed fatalerr.texi to fatalerr.t.Joel Sherrill1998-10-191-47/+0
* Renamed cputable.texi to cputable.t.Joel Sherrill1998-10-191-119/+0
