path: root/doc/supplements (follow)
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-072-1/+5
| | | | | * Makefile.am: mips64orion port removed as mips port more completely covers the MIPS family.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-0715-1383/+9
| | | | | | | | | * mips64orion/.cvsignore, mips64orion/BSP_TIMES, mips64orion/ChangeLog, mips64orion/Makefile.am, mips64orion/bsp.t, mips64orion/callconv.t, mips64orion/cpumodel.t, mips64orion/cputable.t, mips64orion/fatalerr.t, mips64orion/intr_NOTIMES.t, mips64orion/memmodel.t, mips64orion/mips64orion.texi, mips64orion/preface.texi, mips64orion/timeBSP.t: Removed.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-1224-12/+48
| | | | * Makefile.am: Cosmetics.
* 2003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-1124-22/+79
* 2003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-2622-0/+77
| | | | | * Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-2622-11/+55
| | | | * cpumodel.t: Obsoleting HP PA-RISC port and removing all references.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-2615-1336/+8
| | | | | | | | * hppa1_1/.cvsignore, hppa1_1/ChangeLog, hppa1_1/Makefile.am, hppa1_1/SIMHPPA_TIMES, hppa1_1/bsp.t, hppa1_1/callconv.t, hppa1_1/cpumodel.t, hppa1_1/cputable.t, hppa1_1/fatalerr.t, hppa1_1/hppa1_1.texi, hppa1_1/intr_NOTIMES.t, hppa1_1/memmodel.t, hppa1_1/preface.texi, hppa1_1/timeSIMHPPA.t: Removed.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-226-6/+15
| | | | * Makefile.am: Merger from rtems-4-6-branch.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-2210-10/+25
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-228-8/+20
* 2003-09-20 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-203-2/+6
| | | | | * supplement.am: Add -I $(top_builddir) TEXI2WWW_ARGS. * Makefile.am: Purge hppa1.1.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-192-0/+5
| | | | * arm.texi: Merge from branch.
| | | | * c4x.texi: Merge from branch.
| | | | * hppa1_1.texi: Merge from branch.
| | | | * i386.texi: Merge from branch.
| | | | * i960.texi: Merge from branch.
| | | | * m68k.texi: Merge from branch.
| | | | * mips.texi: Merge from branch.
| | | | * mips64orion.texi: Merge from branch.
| | | | * powerpc.texi: Merge from branch.
| | | | * sh.texi: Merge from branch.
| | | | * sparc.texi: Merge from branch.
| | | | * template.texi: Merge from branch.
* Merger from rtems-4-6-branchRalf Corsepius2003-05-2222-12/+56
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-282-0/+42
| | | | * .cvsignore: New file.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-1/+5
| | | | * template.texi: Set @setfilename template.info.
| | | | * sparc.texi: Set @setfilename sparc.info.
| | | | * sh.texi: Set @setfilename sh.info.
| | | | * powerpc.texi: Set @setfilename powerpc.info.
| | | | * mips64orion.texi: Set @setfilename mips64orion.info.
| | | | * mips.texi: Set @setfilename mips.info.
| | | | * m68k.texi: Set @setfilename m68k.info.
| | | | * i960.texi: Set @setfilename i960.info.
| | | | * i386.texi: Set @setfilename i386.info.
| | | | * hppa1_1.texi: Set @setfilename hppa1_1.info.
| | | | * c4x.texi: Set @setfilename c4x.info.
| | | | * arm.texi: Set @setfilename arm.info.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-1/+16
| | | | * Makefile.am: Add c4x, cosmetical changes.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-255-23/+131
| | | | | | * Makefile.am: New. * c4x.texi, cpumodel.t, timeBSP.t: Various minor changes to get them building.
* 2003-01-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-2412-0/+1378
| | | | | | * BSP_TIMES, bsp.t, c4x.texi, callconv.t, cpumodel.t, cputable.t, fatalerr.t, intr_NOTIMES.t, memmodel.t, preface.texi, timeBSP.t: New files. These should have been added long ago.
* 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-242-4/+4
| | | | * supplements.am: Remove AM_MAKEINFOFLAGS, TEXI2DVI, TEXI2PDF.
* 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-2422-111/+155
| | | | * Makefile.am: Put GENERATED_FILES into $builddir.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-232-3/+8
| | | | | * supplements.am: Use automake rules to build ps, pdf, info. Various minor changes.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-2244-162/+184
| | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-223-897/+5
| | | | | * wksheets.texi: Remove from CVS. * timing.texi: Remove from CVS.
* 2003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-2133-44/+88
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-12-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-082-1/+5
| | | | * supplement.am: Append -I $(topsrc_dir) to AM_MAKEINFOFLAGS.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-1333-44/+88
* 2002-11-13 Jay Monkman <jtm@smoothsmoothie.com>Joel Sherrill2002-11-132-123/+53
| | | | * intr_NOTIMES.t: Real version submitted.
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-2433-44/+88
