index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
doc
supplements
sparc
Makefile
follow
Commit message (
Collapse
Author
Age
Lines
Changed copyright date to 1999.
Joel Sherrill
1999-11-16
1
-1
+1
Cleaned up to install dvi, use native texi2dvi, etc..
Joel Sherrill
1999-10-11
1
-5
+6
Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the
Joel Sherrill
1999-10-07
1
-1
+1
pdf version of figures.
Numerous minor changes required to transition to the latest version
Joel Sherrill
1999-10-01
1
-2
+7
of texinfo and TeX. This version of the tools can produce PDF with figures included.
Removed concept of distribution level.
Joel Sherrill
1999-07-03
1
-1
+0
Moved things around so html and clean were above stanzas which generate
Joel Sherrill
1998-10-19
1
-17
+15
chapters.
All of the Supplemental manuals are now generated as automatically
Joel Sherrill
1998-10-19
1
-31
+64
as possible.
Makefiles in much better shape even though not all files have automatically
Joel Sherrill
1998-10-19
1
-16
+41
generated menus yet.
Worksheets now generated from a common file and the node info structure
Joel Sherrill
1998-10-19
1
-10
+26
is generated automatically.
Corrected paths after moving all supplements into a subdirectory.
Joel Sherrill
1998-04-11
1
-8
+8
Taking care of minor build problems
Joel Sherrill
1998-03-30
1
-4
+2
Making the stanza right and improving the way the isntall directories are built
Joel Sherrill
1998-03-30
1
-16
+10
Corrected distribution levels for html
Joel Sherrill
1998-03-30
1
-1
+1
Added distribution level to each manual
Joel Sherrill
1998-03-30
1
-1
+3
Updated copyrights
Joel Sherrill
1998-02-06
1
-1
+1
added CVS Id string
Joel Sherrill
1997-06-04
1
-0
+2
Initial revision
Joel Sherrill
1997-05-27
1
-0
+90
