* supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
