* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 2 | -12/+12 | |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 2 | -12/+46 | |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | |||||
* | Fixed node links. | Joel Sherrill | 1997-08-04 | 3 | -3/+3 | |
* | Added more info. | Joel Sherrill | 1997-07-31 | 6 | -272/+276 | |
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 2 | -2/+70 | |
* | updated to properly reflect powerpc | Joel Sherrill | 1997-07-02 | 6 | -228/+86 | |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 20 | -0/+3307 | |
This version has had some initial work done to convert it to be PowerPC specific. |
