* powerpc.texi: Merge from branch.
* powerpc.texi: Set @setfilename powerpc.info.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
viewer can have section headings.
figures included.
generated menus yet.
chapters.
This version has had some initial work done to convert it to
be PowerPC specific.
