* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+1 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -2/+3 |
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -14/+12 |
* | Renamed a lot and got as much as possible automatically generated. | Joel Sherrill | 1998-10-19 | 1 | -16/+1 |
* | Added idle_task_stack_size field to CPU Table. | Joel Sherrill | 1998-10-12 | 1 | -0/+6 |
* | updates | Joel Sherrill | 1998-02-11 | 1 | -18/+21 |
* | Updated copyrights | Joel Sherrill | 1998-02-06 | 1 | -1/+1 |
* | Added definations for serial_per_sec, serial_rate, and serial_xon_xoff. | Jennifer Averett | 1997-12-02 | 1 | -6/+6 |
* | Modified referances to SPARC to PowerPC. Updated the Information Table to | Jennifer Averett | 1997-12-02 | 1 | -6/+23 |
| | | | | | | | match the one in CPU.H. Added spurious_handler and exceptions_in_RAM items. Added definations for clicks_per_usec, spurious_handler,exceptions_in_RAM, serial_external_clock, serial_cts_rts, timer_average_overhead, and timer_least_valid. | ||||
* | Updated to the PowerPC. | Joel Sherrill | 1997-07-02 | 1 | -1/+35 |
* | New files -- PowerPC supplement is based on the SPARC supplement. | Joel Sherrill | 1997-07-01 | 1 | -0/+111 |
This version has had some initial work done to convert it to be PowerPC specific. |
