* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+6 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | pdf version of figures. | ||||
* | Enabled table of contents generation so the left hand side of the PDF | Joel Sherrill | 1999-10-07 | 1 | -1/+1 |
| | | | | viewer can have section headings. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 2 | -3/+8 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Changed date. | Joel Sherrill | 1999-04-23 | 1 | -0/+2 |
* | New files copied from template and personalized. | Joel Sherrill | 1998-11-23 | 12 | -0/+1314 |
