path: root/doc/supplements/mips64orion/version.texi (follow)
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-301-2/+2
| | | | | * stamp-vti, verstion.texi: Regenerated.
* regeneratedJoel Sherrill2002-01-201-2/+3
* 2002-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-201-2/+2
| | | | * supplement.am: Replace TEXI_COMMON with AM_MAKEINFOFLAGS.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-2/+2
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-011-0/+3
Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
