* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* bsp.t, BSP_TIMES, callconv.t, ChangeLog, cpumodel.t, cputable.t,
fatalerr.t, intr_NOTIMES.t, Makefile.am, memmodel.t, mips.texi,
preface.texi, stamp-vti, timeBSP.t, version.texi: New files.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
