path: root/doc/supplements/i386/i386.texi (follow)
* Switched from presenting timing data based on CPU models to presenting itJoel Sherrill1998-08-131-2/+2
| | | | based on board model.
* Corrected paths after moving all supplements into a subdirectory.Joel Sherrill1998-04-111-4/+4
* Added variables for dates and revision infoJoel Sherrill1998-03-261-4/+4
* Updated copyrightsJoel Sherrill1998-02-061-1/+1
* minor updates .. mostly versionJoel Sherrill1998-01-231-12/+5
* added CVS Id stringJoel Sherrill1997-06-041-0/+2
* changed edition and version informationJoel Sherrill1997-06-041-2/+2
* Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1997-05-311-2/+2
| | | | | | | | to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
* fixed typosJoel Sherrill1997-05-301-6/+6
* version changedJoel Sherrill1997-05-281-2/+2
* 4.0.0 release docsJoel Sherrill1997-05-281-2/+2
* Initial revisionJoel Sherrill1997-05-271-0/+123
