path: root/doc/started_ada (follow)
* Updated version information.Joel Sherrill1998-08-131-25/+25
* Updated the disk space required.Joel Sherrill1998-08-131-2/+2
| | | | Fixed a typo in the hello world example.
* Corrected name of build script and other minor things in the list ofJoel Sherrill1998-08-131-9/+13
| | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree.
* "arc" renamed to "archive".Joel Sherrill1998-04-141-31/+43
| | | | Pictures now in ASCII for maintenance purposes.
* Changed arc to archive.Joel Sherrill1998-04-145-47/+26
| | | | Switched self-maintaining ASCII tree picture.
* Now builds for all formats and includes urlsJoel Sherrill1998-04-142-14/+31
* Added rudimentary section on reading the documentation for each toolJoel Sherrill1998-04-141-0/+10
* Comments from Chris JohnsJoel Sherrill1998-04-142-1/+33
* Suggestions from Eric NorumJoel Sherrill1998-04-142-86/+72
* added ASCII versions of directory tree figuresJoel Sherrill1998-04-131-4/+22
* Updated to include Steve's figures for the first time.Joel Sherrill1998-04-132-12/+80
* MistakeJoel Sherrill1998-04-131-122/+0
* Added Resources on the Internet sectionJoel Sherrill1998-04-133-11/+49
* Fixed directory name for gnu tools ftp siteJoel Sherrill1998-04-131-2/+2
* Updated version of binutilsJoel Sherrill1998-04-131-10/+10
* Now a passable Ada manualJoel Sherrill1998-04-117-92/+268
* Added cross development and real-time embedded systems background.Joel Sherrill1998-04-111-1/+1
* Base line -- copied from C/C++Joel Sherrill1998-04-1110-0/+1238
