1999-02-09 | Changed version numbers. | Joel Sherrill | 1 | -10/+10 | |
1998-10-27 | Version changed. | Joel Sherrill | 2 | -9/+9 | |
1998-10-27 | Updated for beta4b | Joel Sherrill | 1 | -3/+3 | |
1998-10-27 | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1 | -1/+0 | |
1998-10-20 | Updated. | Joel Sherrill | 1 | -14/+16 | |
1998-10-20 | Added more disk space to the requirements and included information | Joel Sherrill | 1 | -3/+8 | |
indicating that it was per target. | |||||
1998-10-20 | Minor cleanup. | Joel Sherrill | 1 | -2/+2 | |
1998-10-20 | Added information about the bit_rtems script. | Joel Sherrill | 1 | -2/+40 | |
1998-10-20 | Added information about the new build scripts. | Joel Sherrill | 1 | -56/+86 | |
Added host OS specific notes. | |||||
1998-10-20 | Added sections and had to change build menu commands. | Joel Sherrill | 1 | -1/+1 | |
1998-08-13 | Updated version information. | Joel Sherrill | 1 | -25/+25 | |
1998-08-13 | Updated the disk space required. | Joel Sherrill | 1 | -2/+2 | |
Fixed a typo in the hello world example. | |||||
1998-08-13 | Corrected name of build script and other minor things in the list of | Joel Sherrill | 1 | -9/+13 | |
needed tools. Corrected path to patches. Added warning about putting the install point under the build tree. | |||||
1998-04-14 | "arc" renamed to "archive". | Joel Sherrill | 1 | -31/+43 | |
Pictures now in ASCII for maintenance purposes. | |||||
1998-04-14 | Changed arc to archive. | Joel Sherrill | 5 | -47/+26 | |
Switched self-maintaining ASCII tree picture. | |||||
1998-04-14 | Now builds for all formats and includes urls | Joel Sherrill | 2 | -14/+31 | |
1998-04-14 | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1 | -0/+10 | |
1998-04-14 | Comments from Chris Johns | Joel Sherrill | 2 | -1/+33 | |
1998-04-14 | Suggestions from Eric Norum | Joel Sherrill | 2 | -86/+72 | |
1998-04-13 | added ASCII versions of directory tree figures | Joel Sherrill | 1 | -4/+22 | |
1998-04-13 | Updated to include Steve's figures for the first time. | Joel Sherrill | 2 | -12/+80 | |
1998-04-13 | Mistake | Joel Sherrill | 1 | -122/+0 | |
1998-04-13 | Added Resources on the Internet section | Joel Sherrill | 3 | -11/+49 | |
1998-04-13 | Fixed directory name for gnu tools ftp site | Joel Sherrill | 1 | -2/+2 | |
1998-04-13 | Updated version of binutils | Joel Sherrill | 1 | -10/+10 | |
1998-04-11 | Now a passable Ada manual | Joel Sherrill | 7 | -92/+268 | |
1998-04-11 | Added cross development and real-time embedded systems background. | Joel Sherrill | 1 | -1/+1 | |
1998-04-11 | Base line -- copied from C/C++ | Joel Sherrill | 10 | -0/+1238 | |
