Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
C version of Getting Started.
to work with pdf generation.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
<Stephan.Wilms@CWA.de>.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
Disabled building of pdf for both the C and Ada Getting Started manuals
because texi2pdf can not handle the construct:
@set URL http://www.rtems.com
@uref{@value{URL},@value{URL}}
It will be reenabled as soon as this problem is fixed.
figures included.
indicating that it was per target.
Added host OS specific notes.
Fixed a typo in the hello world example.
needed tools.
Corrected path to patches.
Added warning about putting the install point under the build tree.
Pictures now in ASCII for maintenance purposes.
Switched self-maintaining ASCII tree picture.
