path: root/doc/started_ada (follow)
* Corrected paths.Joel Sherrill2000-05-171-3/+3
* Updated versions.Joel Sherrill2000-05-081-4/+4
* Now sharing the "buildrt.t" or Building RTEMS chapter with theJoel Sherrill2000-05-082-142/+4
| | | | C version of Getting Started.
* Modifed to avoid using @uref directive since that does not seemJoel Sherrill2000-05-041-9/+14
| | | | to work with pdf generation.
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-043-34/+121
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill2000-05-022-4/+8
| | | | <Stephan.Wilms@CWA.de>.
* Patch rtemsdoc-4.5.0-rc-3.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill2000-05-011-9/+9
| | | | | | | | | | | | | | | | | | | | | | | | | It addresses: * .cvsignore (only minor changes to yours, as they were pretty clean, most changes result from my mkcvsignore script being overly pedantic sorting entries alphabetically.) * timing.t handling and time<BSP>_.texi handling in supplements * network.t handling in bsp_howto * RTEMS_DATE and RTEMS_UPDATE handling in configure.in. [It actually is a hack, as we could apply automake's version.texi handling instead - I know think to understand what automake does with it.] * avoid using temporary files; Therefore a new tool called bmenu2, derived from bemenu, is introduced, which reads a single file from stdin and writes to stdio. To apply: cd rtemsdoc patch -p1 < rtemsdoc-4.5.0-rc-3.diff cvs rm -f bsp_howto/network.t cvs add tools/bmenu/bmenu2.c ./bootstrap BTW: word-replace now is unused. It could be removed if you like to.
* New files. First attempt.Joel Sherrill2000-04-271-0/+23
* Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-04-264-93/+56
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
* Merged changes from 4.5 branch and removed that branch.Joel Sherrill2000-04-252-9/+13
* Changed copyright date to 1999.Joel Sherrill1999-11-169-9/+9
* Fixing many lines that are too long to format cleanly.Joel Sherrill1999-10-251-8/+8
* Cleaned up to install dvi, use native texi2dvi, etc..Joel Sherrill1999-10-111-4/+4
* Remove $(PROJECT).pdf not *.pdf. We were accidentally removing theJoel Sherrill1999-10-071-3/+3
| | | | | | | | | | | | pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed.
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-013-11/+16
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Removed concept of distribution level.Joel Sherrill1999-07-031-1/+0
* Changed version numbers.Joel Sherrill1999-02-091-10/+10
* Version changed.Joel Sherrill1998-10-272-9/+9
* Updated for beta4bJoel Sherrill1998-10-271-3/+3
* Corrected 2nd invocation of texi2dvi so indices are built.Joel Sherrill1998-10-271-1/+0
* Updated.Joel Sherrill1998-10-201-14/+16
* Added more disk space to the requirements and included informationJoel Sherrill1998-10-201-3/+8
| | | | indicating that it was per target.
* Minor cleanup.Joel Sherrill1998-10-201-2/+2
* Added information about the bit_rtems script.Joel Sherrill1998-10-201-2/+40
* Added information about the new build scripts.Joel Sherrill1998-10-201-56/+86
| | | | Added host OS specific notes.
* Added sections and had to change build menu commands.Joel Sherrill1998-10-201-1/+1
* Updated version information.Joel Sherrill1998-08-131-25/+25
* Updated the disk space required.Joel Sherrill1998-08-131-2/+2
| | | | Fixed a typo in the hello world example.
* Corrected name of build script and other minor things in the list ofJoel Sherrill1998-08-131-9/+13
| | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree.
* "arc" renamed to "archive".Joel Sherrill1998-04-141-31/+43
| | | | Pictures now in ASCII for maintenance purposes.
* Changed arc to archive.Joel Sherrill1998-04-145-47/+26
| | | | Switched self-maintaining ASCII tree picture.
* Now builds for all formats and includes urlsJoel Sherrill1998-04-142-14/+31
* Added rudimentary section on reading the documentation for each toolJoel Sherrill1998-04-141-0/+10
* Comments from Chris JohnsJoel Sherrill1998-04-142-1/+33
* Suggestions from Eric NorumJoel Sherrill1998-04-142-86/+72
* added ASCII versions of directory tree figuresJoel Sherrill1998-04-131-4/+22
* Updated to include Steve's figures for the first time.Joel Sherrill1998-04-132-12/+80
* MistakeJoel Sherrill1998-04-131-122/+0
* Added Resources on the Internet sectionJoel Sherrill1998-04-133-11/+49
* Fixed directory name for gnu tools ftp siteJoel Sherrill1998-04-131-2/+2
* Updated version of binutilsJoel Sherrill1998-04-131-10/+10
* Now a passable Ada manualJoel Sherrill1998-04-117-92/+268
* Added cross development and real-time embedded systems background.Joel Sherrill1998-04-111-1/+1
* Base line -- copied from C/C++Joel Sherrill1998-04-1110-0/+1238
