* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 9 | -9/+9 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -8/+8 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -4/+4 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -3/+3 |
| | | | | | | | | | | | | pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 3 | -11/+16 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Changed version numbers. | Joel Sherrill | 1999-02-09 | 1 | -10/+10 |
* | Version changed. | Joel Sherrill | 1998-10-27 | 2 | -9/+9 |
* | Updated for beta4b | Joel Sherrill | 1998-10-27 | 1 | -3/+3 |
* | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1998-10-27 | 1 | -1/+0 |
* | Updated. | Joel Sherrill | 1998-10-20 | 1 | -14/+16 |
* | Added more disk space to the requirements and included information | Joel Sherrill | 1998-10-20 | 1 | -3/+8 |
| | | | | indicating that it was per target. | ||||
* | Minor cleanup. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Added information about the bit_rtems script. | Joel Sherrill | 1998-10-20 | 1 | -2/+40 |
* | Added information about the new build scripts. | Joel Sherrill | 1998-10-20 | 1 | -56/+86 |
| | | | | Added host OS specific notes. | ||||
* | Added sections and had to change build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -1/+1 |
* | Updated version information. | Joel Sherrill | 1998-08-13 | 1 | -25/+25 |
* | Updated the disk space required. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
| | | | | Fixed a typo in the hello world example. | ||||
* | Corrected name of build script and other minor things in the list of | Joel Sherrill | 1998-08-13 | 1 | -9/+13 |
| | | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree. | ||||
* | "arc" renamed to "archive". | Joel Sherrill | 1998-04-14 | 1 | -31/+43 |
| | | | | Pictures now in ASCII for maintenance purposes. | ||||
* | Changed arc to archive. | Joel Sherrill | 1998-04-14 | 5 | -47/+26 |
| | | | | Switched self-maintaining ASCII tree picture. | ||||
* | Now builds for all formats and includes urls | Joel Sherrill | 1998-04-14 | 2 | -14/+31 |
* | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1998-04-14 | 1 | -0/+10 |
* | Comments from Chris Johns | Joel Sherrill | 1998-04-14 | 2 | -1/+33 |
* | Suggestions from Eric Norum | Joel Sherrill | 1998-04-14 | 2 | -86/+72 |
* | added ASCII versions of directory tree figures | Joel Sherrill | 1998-04-13 | 1 | -4/+22 |
* | Updated to include Steve's figures for the first time. | Joel Sherrill | 1998-04-13 | 2 | -12/+80 |
* | Mistake | Joel Sherrill | 1998-04-13 | 1 | -122/+0 |
* | Added Resources on the Internet section | Joel Sherrill | 1998-04-13 | 3 | -11/+49 |
* | Fixed directory name for gnu tools ftp site | Joel Sherrill | 1998-04-13 | 1 | -2/+2 |
* | Updated version of binutils | Joel Sherrill | 1998-04-13 | 1 | -10/+10 |
* | Now a passable Ada manual | Joel Sherrill | 1998-04-11 | 7 | -92/+268 |
* | Added cross development and real-time embedded systems background. | Joel Sherrill | 1998-04-11 | 1 | -1/+1 |
* | Base line -- copied from C/C++ | Joel Sherrill | 1998-04-11 | 10 | -0/+1238 |
