path: root/doc/started_ada/started_ada.texi (unfollow)
2000-04-26Patch rtemsdoc-4.5.0-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
which contains the bulk of converting the documentation tree to automake and GNU conventions. Comments follow: This is the automake port of rtemsdoc. To apply: cvs co rtemsdoc cd rtemsdoc sh cvs-rm.sh patch -p0 < rtemsdoc-4.5.0-rc-0.diff sh cvs-add.sh [Attention: cvs-rm.sh and cvs-add.sh directly modify cvs] Known bugs: 1) src2html is not supported (yet? - Is this supposed to work?) 2) all *.pdf images now are generated on-the-fly, but not yet deleted during "make distclean" 3) All supplements, including the templated ones, get build and installed. 4) Building outside of the source tree is completely untested and very likely does not work. 5) Make [ps|pdf] are not (yet) supported, make [dvi|info] are supported by automake's default texinfo rules. Fixing 2, 3 and 5 is almost trivial and needs to be done. 4) is a matter of testing and tool-properties, for now it is simply untested. General issues: * gif vs jpg vs png. I would recommend to replace all images with pngs to avoid potential copyright issues (gif) or lack in quality (jpg, jpg is good for real world photographs, but extremely poor on artificial images, graphs). * pdf images do net get placed correctly in pdf-documents. * texinfo: We now use a local copy of texinfo-4.0's texinfo.tex in texinfo/texinfo.tex for generating infos. However pdftex's system-wide texinfo.tex and pdftexinfo.tex are used for generating *.dvi, *.ps, *.pdf. * .cvsignore files still missing. * I have renamed the supplements filename not to use c_<supplement>, because automake seems to have problems with it. Notes: * Again, I recommend not to put any generated files into CVS. Here, this comprises some *texi, all *.pdf and many *.html pages. Ie. I recommend to run make maintainer-clean before checking in any files. * To get building started, this should be sufficient: ./bootstrap ./configure cd tools; make; cd .. make info * To make a public tarball: [cvs co ; ./bootstrap] ./configure cd tools; make; cd .. make info [make clean] make dist => This generates a rtems-<version>.tar.gz in the toplevel directory. => Building the tools only is required after a "cvs co", but not in a distribution tarball.
1999-11-16Changed copyright date to 1999.Joel Sherrill1-1/+1
1999-10-01Numerous minor changes required to transition to the latest versionJoel Sherrill1-1/+1
of texinfo and TeX. This version of the tools can produce PDF with figures included.
1998-04-11Base line -- copied from C/C++Joel Sherrill1-8/+8
1998-04-10Printed copy given to Steve and MarkJoel Sherrill1-9/+9
1998-04-10In texinfo nicely with all version dependent informationJoel Sherrill1-5/+9
now in variables and some updates already in place.
1998-04-09Now builds clean for info, html, and ps.Joel Sherrill1-8/+8
1998-04-09base versionJoel Sherrill1-30/+22
1998-03-26Added variables for dates and revision infoJoel Sherrill1-4/+4
1998-02-06Updated copyrightsJoel Sherrill1-1/+1
1998-01-23minor updates .. mostly versionJoel Sherrill1-4/+5
1997-07-31corrected typos and changes LANGUAGE to RTEMS-LANGUAGE.Joel Sherrill1-2/+2
1997-06-04added CVS Id stringJoel Sherrill1-0/+2
1997-06-04changed edition and version informationJoel Sherrill1-2/+2
1997-05-31Changed bitwise OR's used to build up option and attribute setsJoel Sherrill1-2/+2
to be correct in either C or Ada. Added the interrupt disable, enable, flash, and is in progress directives. changed "97" to "1997"
1997-05-28version changedJoel Sherrill1-2/+2
1997-05-284.0.0 release docsJoel Sherrill1-2/+2
1997-05-27Initial revisionJoel Sherrill1-0/+116
