* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -6/+26 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 1 | -8/+8 |
* | Added more disk space to the requirements and included information | Joel Sherrill | 1998-10-20 | 1 | -3/+8 |
| | | | | indicating that it was per target. | ||||
* | Updated the disk space required. | Joel Sherrill | 1998-08-13 | 1 | -2/+2 |
| | | | | Fixed a typo in the hello world example. | ||||
* | Changed arc to archive. | Joel Sherrill | 1998-04-14 | 1 | -1/+1 |
| | | | | Switched self-maintaining ASCII tree picture. | ||||
* | Now a passable Ada manual | Joel Sherrill | 1998-04-11 | 1 | -0/+61 |
* | Base line -- copied from C/C++ | Joel Sherrill | 1998-04-11 | 1 | -0/+36 |
