path: root/doc/started_ada/gdb.t (follow)
* 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-271-18/+18
| | | | | | * buildada.t, gdb.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax).
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+1
* Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill2000-05-021-3/+6
| | | | <Stephan.Wilms@CWA.de>.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Changed arc to archive.Joel Sherrill1998-04-141-3/+3
| | | | Switched self-maintaining ASCII tree picture.
* Now a passable Ada manualJoel Sherrill1998-04-111-15/+53
* Base line -- copied from C/C++Joel Sherrill1998-04-111-0/+194
