path: root/doc/started_ada/buildrt.t (follow)
* Modified to correct references to gmake per comment from Stephan WilmsJoel Sherrill2000-05-021-1/+2
| | | | <Stephan.Wilms@CWA.de>.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Added information about the bit_rtems script.Joel Sherrill1998-10-201-2/+40
* Changed arc to archive.Joel Sherrill1998-04-141-1/+1
| | | | Switched self-maintaining ASCII tree picture.
* Now builds for all formats and includes urlsJoel Sherrill1998-04-141-2/+2
* Comments from Chris JohnsJoel Sherrill1998-04-141-0/+32
* Now a passable Ada manualJoel Sherrill1998-04-111-14/+15
* Base line -- copied from C/C++Joel Sherrill1998-04-111-0/+70
