* | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-27 | 1 | -93/+93 |
| | | | | | | * buildada.t, gdb.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | ||||
* | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-01-17 | 1 | -1/+90 |
| | | | | | | | * SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | ||||
* | Purged as many egcs references as possible. | Joel Sherrill | 2000-06-10 | 1 | -1/+1 |
* | Corrected paths. | Joel Sherrill | 2000-05-17 | 1 | -3/+3 |
* | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 2000-05-04 | 1 | -9/+14 |
| | | | | to work with pdf generation. | ||||
* | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 2000-05-04 | 1 | -11/+78 |
| | | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | ||||
* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 1 | -1/+1 |
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 1 | -7/+7 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Version changed. | Joel Sherrill | 1998-10-27 | 1 | -1/+1 |
* | Added information about the new build scripts. | Joel Sherrill | 1998-10-20 | 1 | -56/+86 |
| | | | | Added host OS specific notes. | ||||
* | Corrected name of build script and other minor things in the list of | Joel Sherrill | 1998-08-13 | 1 | -9/+13 |
| | | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree. | ||||
* | "arc" renamed to "archive". | Joel Sherrill | 1998-04-14 | 1 | -31/+43 |
| | | | | Pictures now in ASCII for maintenance purposes. | ||||
* | Changed arc to archive. | Joel Sherrill | 1998-04-14 | 1 | -41/+20 |
| | | | | Switched self-maintaining ASCII tree picture. | ||||
* | Now builds for all formats and includes urls | Joel Sherrill | 1998-04-14 | 1 | -12/+29 |
* | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1998-04-14 | 1 | -0/+10 |
* | Suggestions from Eric Norum | Joel Sherrill | 1998-04-14 | 1 | -85/+71 |
* | added ASCII versions of directory tree figures | Joel Sherrill | 1998-04-13 | 1 | -4/+22 |
* | Updated to include Steve's figures for the first time. | Joel Sherrill | 1998-04-13 | 1 | -11/+77 |
* | Added Resources on the Internet section | Joel Sherrill | 1998-04-13 | 1 | -8/+7 |
* | Now a passable Ada manual | Joel Sherrill | 1998-04-11 | 1 | -32/+101 |
* | Base line -- copied from C/C++ | Joel Sherrill | 1998-04-11 | 1 | -0/+351 |
