2004-09-29 | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+0 | |
* configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry, porting/cpumodels.t, started/buildc.t, started_ada/buildada.t, user/preface.texi: i960 obsoleted. | |||||
2004-01-07 | 2004-01-07 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -3/+0 | |
* buildada.t: mips64orion port removed as mips port more completely covers the MIPS family. | |||||
2003-08-27 | 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -93/+93 | |
* buildada.t, gdb.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax). | |||||
2002-01-17 | 2001-01-17 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+90 | |
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation. | |||||
2000-06-10 | Purged as many egcs references as possible. | Joel Sherrill | 1 | -1/+1 | |
2000-05-17 | Corrected paths. | Joel Sherrill | 1 | -3/+3 | |
2000-05-04 | Modifed to avoid using @uref directive since that does not seem | Joel Sherrill | 1 | -9/+14 | |
to work with pdf generation. | |||||
2000-05-04 | Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de> | Joel Sherrill | 1 | -11/+78 | |
including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information. | |||||
1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -7/+7 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1998-10-27 | Version changed. | Joel Sherrill | 1 | -1/+1 | |
1998-10-20 | Added information about the new build scripts. | Joel Sherrill | 1 | -56/+86 | |
Added host OS specific notes. | |||||
1998-08-13 | Corrected name of build script and other minor things in the list of | Joel Sherrill | 1 | -9/+13 | |
needed tools. Corrected path to patches. Added warning about putting the install point under the build tree. | |||||
1998-04-14 | "arc" renamed to "archive". | Joel Sherrill | 1 | -31/+43 | |
Pictures now in ASCII for maintenance purposes. | |||||
1998-04-14 | Changed arc to archive. | Joel Sherrill | 1 | -41/+20 | |
Switched self-maintaining ASCII tree picture. | |||||
1998-04-14 | Now builds for all formats and includes urls | Joel Sherrill | 1 | -12/+29 | |
1998-04-14 | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1 | -0/+10 | |
1998-04-14 | Suggestions from Eric Norum | Joel Sherrill | 1 | -85/+71 | |
1998-04-13 | added ASCII versions of directory tree figures | Joel Sherrill | 1 | -4/+22 | |
1998-04-13 | Updated to include Steve's figures for the first time. | Joel Sherrill | 1 | -11/+77 | |
1998-04-13 | Added Resources on the Internet section | Joel Sherrill | 1 | -8/+7 | |
1998-04-11 | Now a passable Ada manual | Joel Sherrill | 1 | -32/+101 | |
1998-04-11 | Base line -- copied from C/C++ | Joel Sherrill | 1 | -0/+0 | |
1998-04-10 | Printed copy given to Steve and Mark | Joel Sherrill | 1 | -2/+2 | |
1998-04-10 | In texinfo nicely with all version dependent information | Joel Sherrill | 1 | -66/+191 | |
now in variables and some updates already in place. | |||||
1998-04-09 | Now builds clean for info, html, and ps. | Joel Sherrill | 1 | -31/+191 | |
1998-04-09 | base version | Joel Sherrill | 1 | -0/+66 | |
