path: root/doc/started_ada/buildada.t (follow)
* 2004-09-29 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-09-291-1/+0
| | | | | | * configure.ac, index.html.in, FAQ/basic.t, FAQ/basic.texi, FAQ/entry, porting/cpumodels.t, started/buildc.t, started_ada/buildada.t, user/preface.texi: i960 obsoleted.
* 2004-01-07 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2004-01-071-3/+0
| | | | | * buildada.t: mips64orion port removed as mips port more completely covers the MIPS family.
* 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-271-93/+93
| | | | | | * buildada.t, gdb.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax).
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-171-1/+90
* Purged as many egcs references as possible.Joel Sherrill2000-06-101-1/+1
* Corrected paths.Joel Sherrill2000-05-171-3/+3
* Modifed to avoid using @uref directive since that does not seemJoel Sherrill2000-05-041-9/+14
| | | | to work with pdf generation.
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-041-11/+78
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* Changed copyright date to 1999.Joel Sherrill1999-11-161-1/+1
* Numerous minor changes required to transition to the latest versionJoel Sherrill1999-10-011-7/+7
| | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included.
* Version changed.Joel Sherrill1998-10-271-1/+1
* Added information about the new build scripts.Joel Sherrill1998-10-201-56/+86
| | | | Added host OS specific notes.
* Corrected name of build script and other minor things in the list ofJoel Sherrill1998-08-131-9/+13
| | | | | | | | needed tools. Corrected path to patches. Added warning about putting the install point under the build tree.
* "arc" renamed to "archive".Joel Sherrill1998-04-141-31/+43
| | | | Pictures now in ASCII for maintenance purposes.
* Changed arc to archive.Joel Sherrill1998-04-141-41/+20
| | | | Switched self-maintaining ASCII tree picture.
* Now builds for all formats and includes urlsJoel Sherrill1998-04-141-12/+29
* Added rudimentary section on reading the documentation for each toolJoel Sherrill1998-04-141-0/+10
* Suggestions from Eric NorumJoel Sherrill1998-04-141-85/+71
* added ASCII versions of directory tree figuresJoel Sherrill1998-04-131-4/+22
* Updated to include Steve's figures for the first time.Joel Sherrill1998-04-131-11/+77
* Added Resources on the Internet sectionJoel Sherrill1998-04-131-8/+7
* Now a passable Ada manualJoel Sherrill1998-04-111-32/+101
* Base line -- copied from C/C++Joel Sherrill1998-04-111-0/+351
