1999-11-16 | Changed copyright date to 1999. | Joel Sherrill | 1 | -1/+1 | |
1999-10-11 | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1 | -4/+4 | |
1999-10-07 | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1 | -3/+3 | |
pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed. | |||||
1999-10-01 | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1 | -3/+8 | |
of texinfo and TeX. This version of the tools can produce PDF with figures included. | |||||
1999-07-03 | Removed concept of distribution level. | Joel Sherrill | 1 | -1/+0 | |
1998-10-27 | Corrected 2nd invocation of texi2dvi so indices are built. | Joel Sherrill | 1 | -1/+0 | |
1998-10-20 | Added sections and had to change build menu commands. | Joel Sherrill | 1 | -1/+1 | |
1998-04-13 | Updated to include Steve's figures for the first time. | Joel Sherrill | 1 | -1/+3 | |
1998-04-13 | Added Resources on the Internet section | Joel Sherrill | 1 | -1/+1 | |
1998-04-11 | Now a passable Ada manual | Joel Sherrill | 1 | -5/+5 | |
1998-04-11 | Base line -- copied from C/C++ | Joel Sherrill | 1 | -4/+4 | |
1998-04-10 | Printed copy given to Steve and Mark | Joel Sherrill | 1 | -2/+2 | |
1998-04-10 | In texinfo nicely with all version dependent information | Joel Sherrill | 1 | -7/+7 | |
now in variables and some updates already in place. | |||||
1998-04-09 | Now builds clean for info, html, and ps. | Joel Sherrill | 1 | -1/+1 | |
1998-04-09 | base version | Joel Sherrill | 1 | -0/+87 | |
