* develenv/direct.t: Remove Getting Started with GNAT/RTEMS.
* started_ada/.cvsignore, started_ada/Makefile.am,
started_ada/buildada.t, started_ada/gdb.t, started_ada/intro.t,
started_ada/require.t, started_ada/sample.t, started_ada/stamp-vti,
started_ada/started_ada.texi, started_ada/tversions.texi,
started_ada/version.texi: Removed.
* posix_users/.cvsignore, rgdb_specs/.cvsignore, rtems_gdb/.cvsignore,
started/.cvsignore, started_ada/.cvsignore: Add more generated files.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
