* | Changed copyright date to 1999. | Joel Sherrill | 1999-11-16 | 10 | -10/+10 |
* | Fixing many lines that are too long to format cleanly. | Joel Sherrill | 1999-10-25 | 2 | -9/+9 |
* | Cleaned up to install dvi, use native texi2dvi, etc.. | Joel Sherrill | 1999-10-11 | 1 | -5/+4 |
* | Remove $(PROJECT).pdf not *.pdf. We were accidentally removing the | Joel Sherrill | 1999-10-07 | 1 | -3/+3 |
| | | | | | | | | | | | | pdf version of figures. Disabled building of pdf for both the C and Ada Getting Started manuals because texi2pdf can not handle the construct: @set URL http://www.rtems.com @uref{@value{URL},@value{URL}} It will be reenabled as soon as this problem is fixed. | ||||
* | Numerous minor changes required to transition to the latest version | Joel Sherrill | 1999-10-01 | 4 | -35/+20 |
| | | | | | of texinfo and TeX. This version of the tools can produce PDF with figures included. | ||||
* | Updated version | Joel Sherrill | 1999-07-09 | 1 | -5/+5 |
* | Removed concept of distribution level. | Joel Sherrill | 1999-07-03 | 1 | -1/+0 |
* | Changed date. | Joel Sherrill | 1999-04-23 | 1 | -13/+13 |
* | Changed dates. | Joel Sherrill | 1999-04-02 | 1 | -4/+4 |
* | Changed versions. | Joel Sherrill | 1999-02-10 | 1 | -5/+5 |
* | Changed versions. | Joel Sherrill | 1999-02-09 | 1 | -14/+14 |
* | Added common problems section after post by Philippe Le Foll | Joel Sherrill | 1999-01-21 | 2 | -1/+82 |
| | | | | <Philippe.LeFoll@fridu.com> on rtems-list. :) | ||||
* | Applied updates from remote work while doing class. | Joel Sherrill | 1998-11-19 | 1 | -2/+2 |
* | Version changed. | Joel Sherrill | 1998-10-27 | 1 | -10/+10 |
* | fixes from David Fiddes | Joel Sherrill | 1998-10-27 | 1 | -8/+6 |
* | Update from David Fiddes. | Joel Sherrill | 1998-10-27 | 4 | -113/+104 |
* | Updated. | Joel Sherrill | 1998-10-20 | 1 | -13/+14 |
* | Minor cleanup. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | Added information about the bit_rtems script. | Joel Sherrill | 1998-10-20 | 1 | -3/+39 |
* | Increased required disk space along with information about the required | Joel Sherrill | 1998-10-20 | 1 | -3/+23 |
| | | | | | | disk space. Added information about GNU makeinfo minimum version. | ||||
* | Added information about the bit_gdb script. | Joel Sherrill | 1998-10-20 | 1 | -3/+35 |
* | Added information about the new build scripts. The biggest thing was | Joel Sherrill | 1998-10-20 | 1 | -59/+73 |
| | | | | | | describing the user.cfg file. Added a section on Solaris 2.x. | ||||
* | Added sections so had to change the build menu commands. | Joel Sherrill | 1998-10-20 | 1 | -2/+2 |
* | New file | Joel Sherrill | 1998-10-12 | 1 | -0/+85 |
* | Added a warning about positioning the INSTALL_POINT under the build | Joel Sherrill | 1998-08-13 | 1 | -0/+4 |
| | | | | tree. | ||||
* | Used http reference for EGCS index. | Joel Sherrill | 1998-04-17 | 1 | -4/+4 |
* | Increased size of archive. | Joel Sherrill | 1998-04-17 | 1 | -1/+1 |
* | "arc" changed to "archive" | Joel Sherrill | 1998-04-14 | 5 | -75/+66 |
| | | | | Pictures now in ASCII. | ||||
* | Now builds for all formats and includes urls | Joel Sherrill | 1998-04-14 | 2 | -17/+44 |
* | Added urls as links | Joel Sherrill | 1998-04-14 | 2 | -10/+22 |
* | Comments from Geoffroy Montel | Joel Sherrill | 1998-04-14 | 1 | -9/+26 |
* | Added rudimentary section on reading the documentation for each tool | Joel Sherrill | 1998-04-14 | 1 | -0/+10 |
* | Comments from Chris Johns | Joel Sherrill | 1998-04-14 | 2 | -4/+37 |
* | Suggestions from Eric Norum | Joel Sherrill | 1998-04-14 | 1 | -76/+68 |
* | added ASCII versions of directory tree figures | Joel Sherrill | 1998-04-13 | 1 | -4/+22 |
* | Now builds for all formats. | Joel Sherrill | 1998-04-13 | 3 | -21/+88 |
| | | | | Updated to include Steve's figures for the first time. | ||||
* | new files | Joel Sherrill | 1998-04-13 | 32 | -0/+0 |
* | Added Resources on the Internet section | Joel Sherrill | 1998-04-13 | 4 | -11/+54 |
* | Added Cygwin32 Chapter | Joel Sherrill | 1998-04-13 | 3 | -2/+11 |
* | New file based on Word document from Geoffroy Montel <g_montel@yahoo.com> | Joel Sherrill | 1998-04-13 | 1 | -0/+347 |
| | | | | who was assisted by D.J.Fiddes@hw.ac.uk. | ||||
* | Corrected Node | Joel Sherrill | 1998-04-11 | 1 | -1/+1 |
* | Mostly correcting case of section headings although a few minor things | Joel Sherrill | 1998-04-11 | 5 | -32/+32 |
| | | | | | were corrected as the Getting Started with GNAT/RTEMS manual was created. | ||||
* | Added cross development and real-time embedded systems background. | Joel Sherrill | 1998-04-11 | 1 | -0/+98 |
* | Printed copy given to Steve and Mark | Joel Sherrill | 1998-04-10 | 4 | -17/+17 |
* | In texinfo nicely with all version dependent information | Joel Sherrill | 1998-04-10 | 8 | -177/+345 |
| | | | | now in variables and some updates already in place. | ||||
* | Now builds clean for info, html, and ps. | Joel Sherrill | 1998-04-09 | 6 | -224/+250 |
* | base version | Joel Sherrill | 1998-04-09 | 8 | -0/+742 |
