It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
Disabled building of pdf for both the C and Ada Getting Started manuals
because texi2pdf can not handle the construct:
@set URL http://www.rtems.com
@uref{@value{URL},@value{URL}}
It will be reenabled as soon as this problem is fixed.
figures included.
<Philippe.LeFoll@fridu.com> on rtems-list. :)
disk space.
Added information about GNU makeinfo minimum version.
describing the user.cfg file.
Added a section on Solaris 2.x.
tree.
Pictures now in ASCII.
Updated to include Steve's figures for the first time.
who was assisted by D.J.Fiddes@hw.ac.uk.
were corrected as the Getting Started with GNAT/RTEMS manual was
created.
