path: root/doc/started (unfollow)
2004-03-312004-03-31 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2-2/+2
* started/buildc.t: Use tar xjf for bzip'ed files. * started/buildrt.t: Use tar xjf to unzip rtems.
2004-03-09Unused.Ralf Corsepius1-2/+0
2004-02-142004-02-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-76/+0
* started/tversions.texi: Remove (Bogus).
2004-02-13Cleanup.Ralf Corsepius1-1/+0
2004-02-042004-02-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill7-47/+57
* HELP.html, index.html.in, rtems_footer.html.in, rtems_header.html.in, FAQ/basic.t, gnu_docs/gnu_footer.html, gnu_docs/index.html, gnu_docs/refcard.html, gnu_docs/rtems_tools_index.html, started/binaries.t, started/buildc.t, started/buildrt.t, started/intro.t, started/require.t, started/sample.t, started/tversions.texi.in: Incorporating changes from pre-4.6.0 review.
2004-02-012004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* configure.ac: Add RTEMSRPMGROUP. * common/rtems.texi.in: Add RTEMSRPMGROUP. * started/binaries.t: Add RTEMSRPMGROUP.
2004-02-012004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-159/+0
* ChangeLog: Merge-in started/ChangeLog. * started/ChangeLog: Remove.
2004-02-012004-02-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-35/+39
* binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
2004-01-202004-01-20 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-1/+6
PR 555/doc * sample.t: Fix RTEMS_MAKEFILE_PATH reference.
2004-01-17Fix broken ChangeLog entry.Ralf Corsepius1-1/+1
2004-01-172003-12-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-0/+5
* Makefile.am: Add tversions.texi.in to EXTRA_DIST.
2003-12-122003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+4
* Makefile.am: Cosmetics.
2003-12-112003-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-13/+20
2003-11-262003-11-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-0/+8
* Makefile.am: Add *.info to CLEANFILES to accomodate automake-1.7f/1.8 breaking building infos.
2003-10-222003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-4/+9
PR 513/doc * started.texi: Rename to be non-language specific.
2003-10-022003-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill9-53/+249
* Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t, sample.t, started.texi: General improvements and merge enough Ada information to justify dropping the Ada specific manual. There is likely still Ada specific information to merge though.
2003-10-022003-10-02 Chris Caudle <chris@chriscaudle.org>Joel Sherrill2-18/+39
* nextstep.t: RTEMS applications can now use main() so correct the discussion of this.
2003-09-262003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-316/+89
* nt.t: Significant update of Windows information. Hopefully this is now more useful.
2003-09-222003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-3/+11
2003-09-192003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill10-138/+230
* .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file.
2003-08-272003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius3-4/+8
* intro.t, nextstep.t: Fix mailing list addresses.
2003-08-272003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius6-171/+177
* buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax).
2003-08-222003-08-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-4/+34
PR 469/doc * buildc.t: Clarifying text on patch file to account for various ways they could be compressed or not.
2003-08-222003-08-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-6/+10
* tversions.texi: Correcting version information.
2003-08-07Merger from rtems-4-6-branchRalf Corsepius3-1/+15
2003-04-172003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-27/+9
* index.html.in: Development Environment Guide should be updated now.
2003-01-282003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-14/+18
* tversions.texi: Updated tool version numbers.
2003-01-252003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-1/+5
* started.texi: Set @setfilename started.info.
2003-01-242003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-8/+12
2003-01-222003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius4-13/+15
* version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
2003-01-222003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2-22/+15
* configure.ac: Require autoconf-2.57. Require automake-1.7.2. Remove started/pictures/Makefile. * started/Makefile.am: Merge-in pictures/Makefile.am * started/pictures/Makefile.am: Remove.
2003-01-212003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+8
2002-11-132002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill8-716/+37
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed.
2002-11-132002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+8
2002-10-242002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-4/+8
2002-07-302002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-4/+4
2002-06-282001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-19/+23
* tverstions.texi: Updated to reflect newer versions.
2002-06-282001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill3-6/+26
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-2/+5
* pictures/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS.
2002-03-202002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2-0/+21
* PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils.
2002-01-20regeneratedJoel Sherrill2-4/+6
2002-01-20regeneratedJoel Sherrill2-4/+4
2002-01-182002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-4/+11
* Makefile.am: Include main.am, require automake-1.5. * pictures/Makefile.am: Require automake-1.5, fix +=.
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2-0/+6
2002-01-172001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill14-577/+1580
* SUPPORT, LICENSE: New files. * Numerous files touched as part of merging the 4.5 branch onto the mainline development trunk and ensuring that the script that cuts snapshots and releases works on the documentation.
2000-08-25Adding ChangeLogs.Joel Sherrill1-0/+3
2000-06-16Bug report from James Housley <jim@thehousleys.net> correctingJoel Sherrill1-1/+1
name of GNU Java Compiler.
2000-06-14Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill1-2/+1
<corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
2000-06-10Purged as many egcs references as possible.Joel Sherrill5-8/+9
2000-06-10Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill3-7/+17
which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
