path: root/doc/started (follow)
* 2003-10-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-222-4/+9
| | | | | PR 513/doc * started.texi: Rename to be non-language specific.
* 2003-10-02 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-10-029-53/+249
| | | | | | | * Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t, sample.t, started.texi: General improvements and merge enough Ada information to justify dropping the Ada specific manual. There is likely still Ada specific information to merge though.
* 2003-10-02 Chris Caudle <chris@chriscaudle.org>Joel Sherrill2003-10-022-18/+39
| | | | | * nextstep.t: RTEMS applications can now use main() so correct the discussion of this.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-262-316/+89
| | | | | * nt.t: Significant update of Windows information. Hopefully this is now more useful.
* 2003-09-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-09-222-3/+11
| | | | * Makefile.am: Merger from rtems-4-6-branch.
* 2003-09-19 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-1910-138/+230
| | | | | | * .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t, nt.t, started.texi: Merge from branch. * tversions.texi.in: New file.
* 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-273-4/+8
| | | | * intro.t, nextstep.t: Fix mailing list addresses.
* 2003-08-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-276-171/+177
| | | | | | * buildc.t, buildrt.t, nt.t, sample.t, tversions.texi: Don't use VARIABLEs containing '-' in @set and @value (violates texi-syntax).
* 2003-08-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-222-4/+34
| | | | | | PR 469/doc * buildc.t: Clarifying text on patch file to account for various ways they could be compressed or not.
* 2003-08-22 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-08-222-6/+10
| | | | * tversions.texi: Correcting version information.
* Merger from rtems-4-6-branchRalf Corsepius2003-08-073-1/+15
* 2003-04-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-04-171-27/+9
| | | | * index.html.in: Development Environment Guide should be updated now.
* 2003-01-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-282-14/+18
| | | | * tversions.texi: Updated tool version numbers.
* 2003-01-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-252-1/+5
| | | | * started.texi: Set @setfilename started.info.
* 2003-01-24 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-242-8/+12
| | | | * Makefile.am: Put GENERATED_FILES into $builddir.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-224-13/+15
| | | | | | | | * version.texi: Remove from CVS. * stamp-vti: Remove from CVS. * .cvsignore: Add version.texi. Add stamp-vti. Re-sort.
* 2003-01-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-01-222-22/+15
| | | | | | | | * configure.ac: Require autoconf-2.57. Require automake-1.7.2. Remove started/pictures/Makefile. * started/Makefile.am: Merge-in pictures/Makefile.am * started/pictures/Makefile.am: Remove.
* 2003-01-21 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-01-213-4/+8
| | | | * stamp-vti, version.texi: Regenerated.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-138-716/+37
| | | | | | * Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi: Removed all references to bit scripts. * gdb.t: Removed.
* 2002-11-13 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-11-133-4/+8
* 2002-10-24 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-243-4/+8
* 2002-07-30 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-07-302-4/+4
| | | | | * stamp-vti, verstion.texi: Regenerated.
* 2001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-282-19/+23
| | | | * tverstions.texi: Updated to reflect newer versions.
* 2001-06-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-06-283-6/+26
| | | | | * buildc.t, gdb.t: Per PR54, updated to reflect multiple compression schemes including bzip2.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-2/+5
| | | | | * pictures/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2002-03-20 Chris Johns <ccj@acm.org>Joel Sherrill2002-03-202-0/+21
| | | | | | * PR137 * buildc.t: Now provides more explicit requirements on $PATH after building binutils.
* regeneratedJoel Sherrill2002-01-202-4/+6
* regeneratedJoel Sherrill2002-01-202-4/+4
* 2002-01-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-183-4/+11
| | | | | * Makefile.am: Include main.am, require automake-1.5. * pictures/Makefile.am: Require automake-1.5, fix +=.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-172-0/+6
| | | | * .cvsignore: Added rtems_header.html and rtems_footer.html.
* 2001-01-17 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-01-1714-577/+1580
* Adding ChangeLogs.Joel Sherrill2000-08-251-0/+3
* Bug report from James Housley <jim@thehousleys.net> correctingJoel Sherrill2000-06-161-1/+1
| | | | name of GNU Java Compiler.
* Patch rtemsdoc-4.5.0-rc-13-cvs.diff.gz from Ralf CorsepiusJoel Sherrill2000-06-141-2/+1
| | | | | | | | <corsepiu@faw.uni-ulm.de> which: * should fix the building rtemsdoc outside of the sourcetree with relative srcdir issue * adds --enable-papersize=[letter|a4|]
* Purged as many egcs references as possible.Joel Sherrill2000-06-105-8/+9
* Patch rtems-rc-4.5.0-21.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-06-103-7/+17
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | which splits the current monolithic specs files into a sequence of subparts. These can be concatenated togather to make a the whole .spec file. This cleans up the maintenance problem of having "all languages" and a "C/C++ only" gccnewlib spec files. Plus it should make it easier to produce variants like the gdb-m68k-bdm which require special hackery. :) Ralf's comments: It addresses the way *.spec.in get composed inside of the source tree. Changes: * Each spec.in is broken into several files (*.add), one *.add file per sub-package. * Each Makefile.am composes spec.ins from the *.add files * Removal of redundant automake support files. * Default value for BuildRoot changed to /tmp/<spec-file-name> * %clean stage added to *specs Advantages (IMHO). * The *.add files are easier to adminstrate and more flexible in comparison to the former *.specs.ins. * gccnewlib_c_only.spec.in now is composed from the same sources as gccnewlib.spec.in (less errors) * If using the default BuildRoot --clean now deletes all files that were generated while building. Notes: * rtems.spec.in has not yet been adapted to the scheme used for the other *spec.ins * Except for cosmetical changes the internals of the *.spec files should not have changed. To Apply: cvs rm -f scripts/binutils/binutils.spec.in cvs rm -f scripts/gccnewlib/gccnewlib.spec.in cvs rm -f scripts/gccnewlib/gccnewlib_c_only.spec.in cvs rm -f scripts/gdb/gdb.spec.in cvs rm -f scripts/config.sub cvs rm -f scripts/config.guess cvs rm -f scripts/install-sh cvs rm -f scripts/mkinstalldirs cvs rm -f scripts/missing patch -p1 < rtems-rc-4.5.0-21.diff cvs add scripts/*/*.add cvs add scripts/*/README
* Patch rtemsdoc-4.5.0-rc-8.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-06-015-49/+50
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf's comments follow: Changes: * Enhanced versioning: - Addition of automake's version.texi support - Replacement of rtemsdoc's former versioning support by automake's versioning support (Abandoning RTEMS-UPDATE-* etc.) - Abandoning setup.texi.in - Add EDITION to each documents Makefile.am - version.texi support in project.am - Addition of maintainer mode (currently only used to prevent incorrectly updating timestamps when users touch automake's version.texi timestamp files (stamp-vti)). * Fixing info dir support - Use texinfo's @dircategory and @direntry instead of infos *-DIR-ENTRY - $(infodir)/dir is now correctly set up * Avoid using temporary files - Pipe texts through REPLACE2 into BMENU2 instead of using temporary files. - Abandon using bmenu in favor of bmenu2 (bmenu could be removed now) * Prepare Makefile.ams for building in a separate buildtree - prefix files with $(srcdir) in Makefile.am for files which must be generated inside of the source tree Notes: * rtemsdoc can not yet be build in a separate source-tree, but we are very close to it. * You as the maintainer of this package now should always use --enable-maintainer-mode to configure rtemsdoc.
* Corrected typo.Joel Sherrill2000-05-281-1/+1
* Added information on Application Makefiles.Joel Sherrill2000-05-281-0/+13
* Added information on how to do this step if you installed toolJoel Sherrill2000-05-281-1/+21
| | | | binaries rather than unpacking everything.
* Added start-?Joel Sherrill2000-05-282-1/+2
* Corrected paths.Joel Sherrill2000-05-172-4/+4
* Added information on the location where the tools are installed.Joel Sherrill2000-05-111-0/+10
* Updated NT editor information to update status on PFE and addJoel Sherrill2000-05-091-6/+24
| | | | pointers to emacs and vim.
* Updated versions.Joel Sherrill2000-05-081-4/+4
* Added more information to the "next step" chapter. The new informationJoel Sherrill2000-05-082-1/+58
| | | | tries to give a pointer about how to approach writing an application.
* Modifed to avoid using @uref directive since that does not seemJoel Sherrill2000-05-042-10/+20
| | | | to work with pdf generation.
* Added nextstep.texiJoel Sherrill2000-05-041-0/+1
* Numerous changes based on comments from Stephan Wilms <Stephan.Wilms@CWA.de>Joel Sherrill2000-05-048-49/+154
| | | | | | including a new section in the Getting Started called "Where to Go From Here", lots of index entries added, and more configuration table information.
* New file.Joel Sherrill2000-05-041-0/+72
