* tverstions.texi: Updated to reflect newer versions.
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression
schemes including bzip2.
* pictures/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR137
* buildc.t: Now provides more explicit requirements on $PATH
after building binutils.
* Makefile.am: Include main.am, require automake-1.5.
* pictures/Makefile.am: Require automake-1.5, fix +=.
name of GNU Java Compiler.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
binaries rather than unpacking everything.
pointers to emacs and vim.
tries to give a pointer about how to approach writing an application.
to work with pdf generation.
including a new section in the Getting Started called "Where to
Go From Here", lots of index entries added, and more configuration
table information.
<Stephan.Wilms@CWA.de>.
This directory was removed post-4.0 to be more in compliance with
GNU standards. Reported by Stephan Wilms <Stephan.Wilms@CWA.de>.
It addresses:
and writes to stdio.
cd rtemsdoc
cvs rm -f bsp_howto/network.t
cvs add tools/bmenu/bmenu2.c
./bootstrap
cvs co rtemsdoc
cd rtemsdoc
sh cvs-rm.sh
sh cvs-add.sh
Known bugs:
during "make distclean"
installed.
likely does not work.
untested.
General issues:
images, graphs).
./bootstrap
./configure
cd tools; make; cd ..
make info
* To make a public tarball:
[cvs co ; ./bootstrap]
./configure
make info
[make clean]
make dist
distribution tarball.
pdf version of figures.
Disabled building of pdf for both the C and Ada Getting Started manuals
because texi2pdf can not handle the construct:
@set URL http://www.rtems.com
@uref{@value{URL},@value{URL}}
It will be reenabled as soon as this problem is fixed.
figures included.
