* ChangeLog: Merge-in started/ChangeLog.
* started/ChangeLog: Remove.
* binaries.t, buildc.t: Use @value{RTEMSRPMPREFIX} in refs to rpms.
PR 555/doc
* sample.t: Fix RTEMS_MAKEFILE_PATH reference.
* Makefile.am: Add tversions.texi.in to EXTRA_DIST.
* Makefile.am: Cosmetics.
PR 513/doc
* started.texi: Rename to be non-language specific.
* Makefile.am, binaries.t, buildc.t, intro.t, nextstep.t, require.t,
sample.t, started.texi: General improvements and merge enough Ada
information to justify dropping the Ada specific manual. There is
likely still Ada specific information to merge though.
* nextstep.t: RTEMS applications can now use main() so correct the
discussion of this.
* nt.t: Significant update of Windows information. Hopefully this is
now more useful.
* .cvsignore, binaries.t, buildc.t, buildrt.t, intro.t, nextstep.t,
nt.t, started.texi: Merge from branch.
* tversions.texi.in: New file.
* intro.t, nextstep.t: Fix mailing list addresses.
* buildc.t, buildrt.t, nt.t, sample.t, tversions.texi:
Don't use VARIABLEs containing '-' in @set and @value (violates
texi-syntax).
PR 469/doc
* buildc.t: Clarifying text on patch file to account for various ways
they could be compressed or not.
* tversions.texi: Correcting version information.
* index.html.in: Development Environment Guide should be updated now.
* tversions.texi: Updated tool version numbers.
* started.texi: Set @setfilename started.info.
* stamp-vti: Remove from CVS.
Add stamp-vti.
Re-sort.
* configure.ac: Require autoconf-2.57.
Require automake-1.7.2.
Remove started/pictures/Makefile.
* started/Makefile.am: Merge-in pictures/Makefile.am
* started/pictures/Makefile.am: Remove.
* Makefile.am, buildc.t, buildrt.t, nt.t, require.t, tversions.texi:
Removed all references to bit scripts.
* gdb.t: Removed.
* tverstions.texi: Updated to reflect newer versions.
* buildc.t, gdb.t: Per PR54, updated to reflect multiple compression
schemes including bzip2.
* pictures/Makefile.am: Remove AUTOMAKE_OPTIONS.
* PR137
* buildc.t: Now provides more explicit requirements on $PATH
after building binutils.
* Makefile.am: Include main.am, require automake-1.5.
* pictures/Makefile.am: Require automake-1.5, fix +=.
name of GNU Java Compiler.
relative srcdir issue
Ralf's comments:
tree.
per sub-package.
Advantages (IMHO).
other *spec.ins
should not have changed.
To Apply:
cvs rm -f scripts/config.sub
cvs rm -f scripts/install-sh
cvs rm -f scripts/missing
cvs add scripts/*/*.add
cvs add scripts/*/README
Ralf's comments follow:
* Enhanced versioning:
- Abandoning setup.texi.in
files (stamp-vti)).
* Fixing info dir support
* Avoid using temporary files
are very close to it.
binaries rather than unpacking everything.
